- Chip board ENC28J60-I/SO
- The board 25MHZ crystal
- The network interface board HR911105A
- 3.3 V power supply pin
- The board size of 56 (mm) x 34 (mm)
- Work with Arduino via SPI
Features:
- 1.95 V to 3.6 V supply voltage
- 1.6 V to 3.6 V interface voltage
- ±2g/±4g/±8g dynamically selectable full-scale
- Output Data Rates (ODR) from 1.56 Hz to 800 Hz
- 12-bit and 8-bit digital output
- I2C digital output interface (operates to 2.25 MHz with 4.7 kΩ pullup)
- Two programmable interrupt pins for six interrupt sources
- Three embedded channels of motion detection
- Orientation (Portrait/Landscape) detection with set hysteresis
- High Pass Filter Data available real-time
- Current Consumption: 6 μA – 165 μA
Documents:
Feature
- Plug-in Network Module having W5200 & Mag Jack
- Usable without H/W design for W5200, Transformer and RJ-45
- Fast evaluation available for W5200 and MCU in the target board
- Supports 8 Independent sockets simultaneously
- Support high speed SPI interface
- Supports Power down mode and Wake-On-Lan function
- Very small form factor (PCB Size : 23mm x 25mm)
Architecture
TCP / IP
W5200
PHY
Embedded in W5200
Interface
10/100 Base-T Ethernet (Auto detect)
Network
Protocol
TCP, UDP, IP, ARP, ICMP, IGMP, PPPoE, MAC
PCB size
23.0mm x 25.0 mm
Connector Type
2.54mm pitch 1×6 Pin header (2 Row)
Input Voltage
3.3V internal operation, 5V tolerant I/O
Temperature
Operation: -40 ~ +85 (Centigrade degree)
Storage: -40 ~ +85 (Centigrade degree)
Power consumption
10/100 Base-T max. 120mA (3.3V)
Свежие комментарии
